kanadacat
- Aug 25, 2005
- Carleton Place, Ont
- 2017 Sidewinder LTX SE
- Carleton Place
Rode my Apex for the first time this year, it has 1000 miles on it and I changed over the updated bars in early December. Anyways I never drove it until last week and as soon as I was on the lake I noticed the machine would drag on when I got off the gas, it was as if the throttle was sticking a little. When I changed over the bars I never touched the cable, simply did the chang over, nothing to it. Anyways I tried both my friends Apex's and their's was fine. When I get off the gas it seems to hesitate before it comes back to zero.
I opened it up thinking maybe I kinked the cable, anyways I loosed the adjustment a little bit figuring it would let the throttle close quickly but it did the same thing when I got back on the lake.
Can someone give me their opinion of what it could be and if possible the proper adjustment specs for the cable and TORS set up.
rerod
I have the same problem and cant figure it out. Someone help.
Soldier'spapa
- Mar 21, 2006
- Naperville, IL
- 2018 Sidewinder Ltx LE 50th Anniversary
kanadacat said:Rode my Apex for the first time this year, it has 1000 miles on it and I changed over the updated bars in early December. Anyways I never drove it until last week and as soon as I was on the lake I noticed the machine would drag on when I got off the gas, it was as if the throttle was sticking a little. When I changed over the bars I never touched the cable, simply did the chang over, nothing to it. Anyways I tried both my friends Apex's and their's was fine. When I get off the gas it seems to hesitate before it comes back to zero.
Can't say for sure but check out this thread.
http://www.ty4stroke.com/viewtopic.php? ... +induction
Len Todd
Kinked cable! Loosen it slightly and see how easy it slides. It should slide very easy.
rerod
I still cant figure it out. I have synchronized the throttle bodies, checked all vacuum lines, checked the tps, and even tighnen the return spring of the throttle cable . The only thing left is the computer.
