rerod
Ok motor heads. Can I use a different boot from the throttle bodies to the motor, or do I have to use the stock boots because of the way the boot aligns the two? Its on a Apex I have spent two years trying to keep my boots on and I have tried everything. The last thing I used was glue and it worked for about a half of season but now the boots are ripped. Thanks
Ted Jannetty
rerod said:Ok motor heads. Can I use a different boot from the throttle bodies to the motor, or do I have to use the stock boots because of the way the boot aligns the two? Its on a Apex I have spent two years trying to keep my boots on and I have tried everything. The last thing I used was glue and it worked for about a half of season but now the boots are ripped. Thanks
Replace them with stock boots and Use these
http://vibrantperformance.com/catalog/i ... c7b6929403
I stock them.
www.turboaddictionparts.com
Ted.
rerod
I have my throttle bodies strapped down and safety wired to the started bolt in front and coil bolts in back and I have my intercooler strapped down.
Ted Jannetty
wheeline said:Ted, will those work on a RX-1?
YES they will!
wheeline
- Jun 27, 2006
Do you have any pictures of them installed? I can't tell for sure where they go.Ted Jannetty said:wheeline said:Ted, will those work on a RX-1?
YES they will!
