apexhank
- Mar 5, 2011
- HUDSON FALLS AND BIG MOOSE LAKE, NY
- 2021 SIDEWINDER LTX GT (soon)!
2019 SIDEWNDER LTX DX 6000 miles
2018 VIPER LTX DX 2200 miles
2014 VIPER LTX DX 8000 + miles
2014 BENNINGTON 22 ft. PONTOON BOAT/ 90 HP Yamaha
I have a 19 Sidewinder LTX- DX, I have to hold the throttle slightly for machine to start. What is the adjustment process to take slack out of cable, or do I raise RPMs a little bit?
snowbiscuit
You don't want to take all the slack out of throttle cable or you could end up with sd84(tors)... if you need to make the adjustment it's on the handle bar riser and your looking for .030-.060 in. free play at throttle lever
apexhank
- Mar 5, 2011
My biggest problem right now is sled won’t idle unless I hold travel open a little. Not sure which way to go with adjustment.You don't want to take all the slack out of throttle cable or you could end up with sd84(tors)... if you need to make the adjustment it's on the handle bar riser and your looking for .030-.060 in. free play at throttle lever
Rtbo
- Feb 18, 2016
- N Syracuse
- 23 SRX
- N Syracuse
Bring it to dealer for warranty. Mine was the same, they changed all kinds of stuff. It was running rich. I think it was the fuel return elbow.
basic700
- Mar 5, 2010
- Norwalk WI
- 2018 Sidewinder STX DX 146
2015 SRViper XTX LE
2009 Nytro XTX
Any update to this???? I went to fire my sled up yesterday (hasn't been started for 2 months and was cold) the idle is too low and would die. Had to hold throttle open a bit for it to start and run.
1. i need to adjust the throttle some way or another to achieve 1500 idle rpm
2. i dumped in some left over 110 octane fuel last spring and it was cold enough the sled wasn't happy with that gas.
-thoughts? Its going to warm up a lot now so i will try it again but thought id bring this post back up and see what you guys think
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
First off, the first sirup is always tough, the fuel is old, the valves are a little rusty, there's not a lot of oil on things and of course if you put race fuel in it that doesn't like to fire & lite off in the cold anyway.
If its old fuel I'd siphon it out of there and get fresh fuel in it. If you mess around to much with it trying to start it and get it to temp, you'll foul the plugs and need to change them. Get it fired up, let it warm and run it hard on the stand or in the field before you shut it down, if you don't, it could foul the plugs and put moisture into the oil and inside the engine.
basic700
- Mar 5, 2010
- Norwalk WI
2015 SRViper XTX LE
2009 Nytro XTX
(First start up) I started it once a month and let fun for 10 mins since last April. but skipped starting it just here in January. so this was the first COLD start, we have had sub zero temps the last couple weeks
basic700
- Mar 5, 2010
- Norwalk WI
2015 SRViper XTX LE
2009 Nytro XTX
2 nytros and another SW started and idled fine. My SW was the only issue, Ran fine but had to keep tension on the throttle
I bet fresh fuel, new plugs, and a good run will clear your issues.
I am not a fan of regular starting a sled in the off season. A short heat cycle builds condensation that idling for 10 mins will never get rid of. On initial startup and idle the fuel mixture is relatively rich that can and will soot up the plugs that won't clear without a proper heat cycle and some higher throttle operation.
We typically don't start and idle our boat motors, PWCs, motorcycles, aircraft, or stored vehicles ect in the off seasons...why has this common procedure with sleds become popular? I never got it.
JM.02c
JM.02c
basic700
- Mar 5, 2010
- Norwalk WI
2015 SRViper XTX LE
2009 Nytro XTX
what # plugs do these SW run
Stock plugs:what # plugs do these SW run
NGK CR8E
Some people are using:
NGK CR9EK....slightly colder with dual electrodes
