This is very important to get right and will cause intermittent backfires,misses or stalling if not right especially if too tight. Much of the flash issues are actually this.
Find this nub about 1 1/4 from pivot. This is where you measure from.
Very lightly press throttle on end with one finger till you hear switch click. At that point a credit card should very easily slide between nub and throttle block.
If it doesn’t fit adjust here
Turn the bars fully left and right and check there also.
Checking in diagnostic mode is not enough.
There is still that tiny travel between switch clicking and resting against block. It must be there. If switch doesn’t click in first step you are probably too tight to begin with. Loosen and go from there.
Angus viper
- Jun 29, 2007
- SW Ontario
- 2015 sr viper se
Good tip thanks! Mine was out, was stalling last ride.
Yamasledder
- Mar 7, 2010
- Brandon, Manitoba, Canada
- 2020 Viper LTX SE
Good tutorial.This is very important to get right and will cause intermittent backfires,misses or stalling if not right especially if too tight. Much of the flash issues are actually this.
View attachment 146668 View attachment 146669
blueironranger
- Feb 3, 2009
- Iron Range MN
- 2014 Viper XTX
2009 Phazer MTX
Helped a guy out on the trail fix this, complaining it would randomly stall when letting off the throttle while turning. I'm running mine on the loose side to avoid any issues since I noticed the cable tension varies a decent amount as you swing the bars back and forth.
ksiesel
- Mar 25, 2016
- Indiana
- 2015 Viper RTX-DX
- Indiana
I’ll second the running loose. As far as I can tell, there really is no downside to running it a bit loose as long as you can still get to 100% open. If mine’s not loose, I have a significant gap left between the bar and the throttle at wide open so I’m choosing to use some of that gap for extra throttle free play to avoid the TORS shutdown.
Allan
Check mine yesterday and it was a little tight. was getting 0% and 99% before loosen it a little. and still getting 0% and 99% after. My other viper I sold would also be at 0% and 99% . never seen the 100%
Clamb
- Oct 2, 2016
- Peoria IL
- 02 Sx viper Er 15 sr viper xtx
- Peoria il
Might be a dumb question but how are you getting to the adjuster? Mines sealed as one piece looks like yours is also. Feel like a idiot asking but?
Peel back the rubber. Lube helps!Might be a dumb question but how are you getting to the adjuster? Mines sealed as one piece looks like yours is also. Feel like a idiot asking but?
Clamb
- Oct 2, 2016
- Peoria IL
- Peoria il
Duh thanks
Janne339
I adjust freeplay om my wife's -16 RTX. Was too tight! Hot starting problems on our saturday ride. Stalling and missfire. Works better now. Maybe its something with T.O.R.S also?
Someone can explain how T.O.R.S works and how to control the function?
Janne339
Ride all sunday and my wife's RTX started pefectly. No sign of hot start problems. Turn key and it fires right upp! Freeplay on loose side but still 99% tps wide open.
Very weird.. Never seen this problems on my own XTX Viper. Only on my wife's RTX.
