mtotguy
- Jan 20, 2011
- Montague, Michigan
- 2016 Rush 800, 2014 Viper RTX, 1983 Excel 3
My wife says the Phazer throttle is "too touchy" for her. Is there a way to make the throttle less responsive?
Jeffz
- Feb 3, 2010
- Cresco, Iowa
- 2008 Yamaha Nytro RTX 40th
2007 Phazer "RTX"
I think Schmidt bros. sells a "smooth" clutch kit.
- Nov 1, 2009
- Winnipeg, Manitoba
- 2009 Phazer RTX
Is it too touchy at engagement or everywhere?
Only way I can think of would be to change the shape of the throttlewheel where cable attaches.Never saw it done on these.Otherwise maybe clutching it under 11000 rpm.Might load it enough to kill the snappiness.Best is to just get her to ride it more.I bet she will get used to it real quick.
mtotguy
- Jan 20, 2011
yamahas said:Is it too touchy at engagement or everywhere?
I've noticed that it is a little annoying at slower speeds. I assume that's what she's talking about. My Nytro does the same thing but not as bad.
- Nov 1, 2009
- 2009 Phazer RTX
i have read about a fix, lowering the engagement might help a bumch. I think its just changing the spring in the primary. 10 min job. il try to find the link.
MikeWalters
- Feb 21, 2010
- Saskatchewan
- 2007 Phazer
I would say the Ulmer Clutch kit made the Phazer much smoother at low speeds.
I ride with kids a lot, kinda think the "smooth" kit from Schmidt would have been nice to try in hindsight.
- Nov 1, 2009
- 2009 Phazer RTX
http://www.ty4stroke.com/viewtopic.php?t=97204
Second paragraph twards the end. might be your fix? Might also have to do a bit of clutch work to get the rpms right on top?
If it is in fact the low end that she dose not like maybe get a hold of ulmer or another clutch guy to get parts and help setting it up right?
09phazermichagan
ulmer's kit helps alot in the slower speeds
snofreak500
Schmidt Bros makes a clutch kit specific to making the throttle response take off at lower speeds way less jerkey its their comfort kit and I think it will do EXACTALLY what you want .
