Hi Folks,
Here's what I have: 2013 short track, base model, 1.25 track (original), 96 studs. Both limiter straps in lowest holes (unchanged).
Last summer I pulled out the skid frame and overhauled it: new slides, bearings where needed, and had both shocks rebuilt. Reinstalled it and discovered right away the track tension was tight. So I gradually backed off the adjuster bolts more and more. Now they are at the loosest setting - any looser and they will be out of the plastic of the lock nuts. But the track is still tighter than it was before the skid frame was out - with no more adjustment available. It is possible the track is (barely) loose enough at this point - I need to measure deflection to be sure. Btw, my fuel economy hasn't changed after all this.
So I am wondering if anyone knows why this has happened. I've double-checked the reassembly. I expected the track would be too loose at the current setting of the adjusters.
Any suggestions much appreciated. Thanks.
