Tore into the RTX today.
dburu2
angelica ny
A few things I found after working on rtx today. First the bolts holding the coils on the plugs was blue locktited I don't know if this could be a problem after many heat cycles but I was told to pull the bolts and clean them. Second was the antifreeze it pegged the tester I didn't have any 100 % to compare to but 50/50 was-34 I may dillute it for better ooling with water wetter.Third one throttle body air box rubber boot was folded under by whoever put it together.Fourth put in the 6# battery used this last year never had a problem starting temps to-20. Fith it looks like the torque arm I used on last years RX-1 will go on in almost the same location. Didn't have to many problems thanks to Alan Ulmer! Hope I don't have to tear it apart on the trail in really cold weather! :rocks:
I should of said it's a battery for a Honda 600 motorcycle,the weight is 6lbs the stock one is 14 lbs, :4STroke: cheepest weight savings you' probably see.
What number is the battery and were did you get it. Hi ,another new yorker, cool.
Yamaha is trying every trick they can, and using expensive metals to save a few pounds. Weight has been the main complaint about these machines. Are they that dumb, that they've never thought of using a lighter battery?
the battery is lighter this year compared to last on the hi perf models,but they still wanted enough of a reserve to start these machines in extreme cold weather,i think a smaller battery would have been ok but they left a little overkill there to keep the non start complaints to a minimum,the rs models use the ytx20-bs battery and the apex/attak models use the ytx14-bs battery which is 25mm narrower with the same height and thickness so its a fw pounds lighter,yamaha has used their heads,even the oil filter is 5 mm shorter to save weight(and clear steering components) but weight savings is weight saving huh
If the filter is 5mm shorter I wonder if it is the same as the RS Vector?
