stohlem
- Jan 11, 2015
- 2017 Sidewinder LTX LE, 2014 Apex XTX
- Illinois
Hey Guys, I changed out flange bolts from torx to hex bolts. What is the torque spec. on 6 bolts? FYI- Anyone that can't find the correct length of bolt and must cut bolts, the bottom 2 holes are not drilled through the turbo. You may bottom out thinking you're tight. Check length.
Pstn head
stohlem
- Jan 11, 2015
- Illinois
Duh, I should have looked there. Thanks
jameson bacon
- Mar 22, 2018
- Maine
- 2018 sidewinder xtx se 141
What size bolts did you end up using??
