Greasemonkey59
I have a 06 Rage GT and I am looking for the TPS specs.WOT and at idle.
Having running problems and I have narrowed it down to the TPS. Did a sweep with the ohm meter and have a bad glitch from 1/4 to 3/4 throttle so I'm getting another one and would like to set it up to factory specs.
Thanks in advance.
Thanks in advance.
Len Todd
This is out of the Nytro Book, but should be very close.
Throttle position sensor voltage:
0.63 ~ 0.73 V
(across the Yellow – Black/Blue wires)
This being a voltage, I suspect that the sled ignition has to be on and possibly even running with the TPS plugged in. Also, I would assume this is the idle setting. I assume you know you use the two fasteners to change the angle of the TPS until you get the above reading on your Digital Multi-meter.
0.63 ~ 0.73 V
Greasemonkey59
Thanks a lot.
Len Todd
You are most welcome!
