Sevey
- Feb 15, 2011
- Collingwood, ON
- www.ty4stroke.com
- 2018 Sidewinder RTX
Be sure to check your front cross shaft up in the tunnel. If the hit was hard enough its likely bent and may have the bolts start tearing through the side of the tunnel
MS
MS
number1kyster
- Dec 10, 2004
- Vermont
- 2018 SW RTX SE
I just replaced bent trackshaft on a 2019 TCat. Sled landed on some rocks coming across a drainage ditch. When I put it in my lathe, it was bent at least 1/2" from one end to other. Owner said he felt serious vibration in running boards and needed a mouth guard to ride it. Lol
Are you talking about the driveshaft?
number1kyster
- Dec 10, 2004
- Vermont
- 2018 SW RTX SE
MS
The cross shaft looks good.
Turboflash
- Mar 18, 2019
- Southern MN
I call it track shaft. Shaft that drives track. Jackshaft was fine.Are you talking about the driveshaft?
