Tracing a vibration
Be sure to check your front cross shaft up in the tunnel. If the hit was hard enough its likely bent and may have the bolts start tearing through the side of the tunnel
MS
I just replaced bent trackshaft on a 2019 TCat. Sled landed on some rocks coming across a drainage ditch. When I put it in my lathe, it was bent at least 1/2" from one end to other. Owner said he felt serious vibration in running boards and needed a mouth guard to ride it. Lol
Are you talking about the driveshaft?
MS
The cross shaft looks good.
