SxVxGeserg
- Feb 1, 2019
- washington
- 2017 side winder mtx 162
so I'm having problems aligning my track i have 17 sidewinder mtx 162 its been having a problem aligning since i got it
i did every thing proper in the back even aligned each wheel with a mallet to make sure its even both sides and everywhere and proper tension but the the second i give it gas the track moves too the right slightly what am i doing wrong or is there something bent i should look at? nothing really looks bent, should i take apart the whole track and redo it?
you don't really noticed when out riding but it looks like its chewing up the track extra
yamadoo
- Jun 3, 2003
10 Vector LTX Blue 9kmiles
11 Venture GT 4k miles
86 SnoScoot(2) for grand kids
Not sure about winder but this was common on procross viper
SxVxGeserg
- Feb 1, 2019
- washington
any known fix? or should i align as good as it gets and run it till the track falls off lolNot sure about winder but this was common on procross viper
yamadoo
- Jun 3, 2003
I just aligned it best I could and have repeatedly heard of track wandering but never track failure... thankfully
SxVxGeserg
- Feb 1, 2019
- washington
yah it looks perfect after i take my time and make sure everything is aligned one spin and it wanders too the right it only goes so far and stays like that just worried of one the front wheels popping off because of that wanderI just aligned it best I could and have repeatedly heard of track wandering but never track failure... thankfully
Thats all you can do!! The chassis has so much flex that you have to hang it evenly or it will walk. I loop a strap so it pulls evenly , run it center the best I can in the back and run it. I had a viper with 8900 miles on the track with zero issues.
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
I measure my adjustment bolts and make sure they are the same length at the desired track tension. The track always wanders side to side on the track clips and wheels when your riding.
Mtnviper
Vendor
It's not uncommon to have the track tensioned a little more on one side then the other in order to get it to track straight. It seems like that I have had to do that on just about every sled I have owned to some degree.
With tracks that are clipped every other window, I will lube the track windows with Sil-glide (silicone lube) to take the dry rubber to hyfax friction out of the equation. Normally I set my track tension first, then adjust the track left or right so that it's centered and call it good.
If think you about it, the track is a 162" long piece of rubber with a single ply of belt and the chances of it being slightly out of square or stretching to some degree are pretty good!
Carla 123
- Feb 27, 2017
- Lester beach
- 2015 viper xtx boosted
17 zr9000 precision stage 3
Same issue on my viper.cannot line track up at all.goes to the right like yours does.can be very frustrating but just ride it.i just make sure tension is good and that's it.as said it moves from side to side
theewarrior
Is this only happening two tracks with the clips on the inside of the rails?
Deeppow16
- Oct 19, 2015
- Montrose, Minnesota
- 2016 Arctic Cat M8000
2002 Polaris 600 XCSP (Sold)
Same problem I have on my '16 M8000 153. I just gave up and ran it. 700 miles later and nothing has happened so I don't worry about it.
iceback
