xrayjohn
- Sep 28, 2010
- Frankfort, IL
- 2006 Apex
- Frankfort, Illinois
After reinstalling my skid, I have been having trouble getting the track to align so that it doesn't wear idler wheels. It seems to be skewed to the left.
How can I get it to move to the right?
oldsledhead
Tighten the left adjuster a touch or loosen the right one a touch.
xrayjohn
- Sep 28, 2010
- Frankfort, IL
- 2006 Apex
track tension
Thanks. I'll try that.
Apex2006
- Oct 26, 2009
- McHenry, IL
- Yamaha Sidewinder SRX-LE 2019
Yamaha Sidewinder XTX 141 2017
Yamaha Viper XTX 2015
Yamaha Sno Scoot 2018
Ski-Doo Renegade XRS 850 2020
Loosen the axle nut to make the adjustments. With the track in the air you can make the slight adjustments using a 14mm deep socket. I like to identify a locator on each side and measure equally from the axle on both sides as a start. Then to fine adjust run the track and you can see whether you need to slightly adjust one side or the other. Don't forget to tighten the axle nut when finished....
Honk
Track will always drift to the loose side
xrayjohn
- Sep 28, 2010
- Frankfort, IL
- 2006 Apex
Thanks, Apex 2006
Didn't know I needed to loosen the axle nut.
Maybe that was my problem.
langow
Re: Thanks, Apex 2006
Without doing that, any adjustment you make to the tensioning screws has no where to go. You'd just be putting tension against the rear axle.
xrayjohn said:Didn't know I needed to loosen the axle nut.
xrayjohn
- Sep 28, 2010
- Frankfort, IL
- 2006 Apex
track tension
Makes sense now that I think about it. Should have seen that!!!
