track change ?
mjgebo2
I am trying to change my track on my 03 rx1 shorty with reverse but I am having trouble removing cover :x I removed all the bolts and the collar but it only moves out about an inch and stops,dont want to force , any suggestions. Thanks
THE REVERSE LEVER FORK GETS STUCK ON THE GEAR SHOULDER INSIDE
TRY WIGGLEING THE LEVER WHERE IT ENTERS THE CHAINCASE-ALSO YO NEED TO REMOVE THE SMALL 10MM? BOLT IN THE CENTER OF COVER
track change
You have to tke out the bolt that is between the two linkages. IT's the part that the linkage swivels on, this part runs out of travel before the shifting fork can release from the gear , Ken.
