3-UP
- Jan 16, 2013
- New Brunswick
- Phazer GT
Looks like the washer that goes on the rear two skid bolts on the inside of the tunnel #42 on TRACK SUSPENSION 2 microfiche or the washer under the clip that holds on your brake rotor but you say it does not fit there?
ATV PRO #11
- Jan 22, 2011
- Garson, MB, CANADA
- 2014 Yamaha Phazer XTX
42 is a fairly thin brass like washer. ID would have to be bigger than that one.
This washer buggin you too??
Dalton
- Mar 13, 2013
- Chippewa Falls, WI
- Sidewinder XTX SE 141
Yamaha Phazer 2007 GT
Yeah unfortunately it isn't that washer either. I had both of those when installing the skid and they are a bit thin like ATV Pro said.
This is bugging the heck out of me.
I took the sled for a ride out on the lake and really kinda beat on it to see if I could get some sort of squeak or faulty noise but nothing. Everything ran smooth as could be.
Still looking through part diagrams and going out to look at the sled back and fourth.
I appreciate everyones help on this!
ATV PRO #11
- Jan 22, 2011
Keep pounding on it, get that sqweek !!! We gotta know where this bad boy goes.Yeah unfortunately it isn't that washer either. I had both of those when installing the skid and they are a bit thin like ATV Pro said.
I do, however, have an incling it's just a spare.
When you did the track change you had to take the brake rotor off....after the spring retainer clip there are 2 washers/shims...then a smaller washer a gasket then rotor.....is it one of the first of the two shims...that's my guess....
