might be good for a ride or 2 but i would not count on it lasting at all. i would replace.
earthling
- Dec 1, 2017
- 2021 SRX
2006 ATTAK
time for a new track
RDOG907
- Jan 5, 2023
- Alaska
- 2017 Yamaha Sidewinder MTX 162
What I thought, I was going to keep it as a backup trackmight be good for a ride or 2 but i would not count on it lasting at all. i would replace.
HighSpeedLowDrag
It failed because it's not a 2.52" pitch track.
Fortress
- Dec 18, 2016
- West Canada
- 2004 RX1
Is 2.52 the best?It failed because it's not a 2.52" pitch track.
2.52 used to be the common track drive pitch from the 90's into at least the mid 20 teens. now 2.86 seems to be the common pitch used by manufacturers for trail sleds.
RobX-1
- Coldwater, OH
To be honest, when I read @HighSpeedLowDrag comment of it not being a 2.52 pitch track, I didn't take that as his recommendation of it being a superior track but that it failed because possibly the OP had 2.86 drivers but was using a 2.52 pitch track but I could be wrong.
I too agree with maim in that if you are limited in what is available for 2.52 pitch tracks, you can always swap out drivers to a 2.86 ones so that you have more of a selection of 2.86 pitch tracks to choose from.
RDOG907
- Jan 5, 2023
- Alaska
It ripped the lug off because it was being rode hard and probably tasted a rock.To be honest, when I read @HighSpeedLowDrag comment of it not being a 2.52 pitch track, I didn't take that as his recommendation of it being a superior track but that it failed because possibly the OP had 2.86 drivers but was using a 2.52 pitch track but I could be wrong.
This is an MTX 162 so it is a 3.00 pitch track. Neither comment really contributed to my question. Everything is stock currently.
I'll probably glue the track and reinforce with some stainless wire around the affected area for now if I ride this year if not then ill likely replace it with a 2ply composit track.
RobX-1
- Coldwater, OH
Well, if you decide to repair, curring time will be your best friend for best results. This is the 3M waterproof sealant that I've used. Your damage does not seem as bad so if anything, I would use something like this to just 'patch up' that area so as to prevent it from fraying/delaminating further.
RDOG907
- Jan 5, 2023
- Alaska
I'll check that out. I was also recommended loctite 404Well, if you decide to repair, curring time will be your best friend for best results. This is the 3M waterproof sealant that I've used. Your damage does not seem as bad so if anything, I would use something like this to just 'patch up' that area so as to prevent it from fraying/delaminating further.
yam429
- Jan 18, 2009
- Saint Michael, MN
- 2009 Nytro XTX, 2010 Vector LTX, 1981 SRX 440, 1989 Inviter, 1991 Snosport, 2004 Snowhawk
- Saint Michael
Carroll Tech is who I use when needing track repair. They repair stud tear outs, missing lugs etc. Located in New York. Cheaper alternative than replacement.
