venturenorth
- Dec 21, 2013
- N Wisc VILAS CTY
- 2011 apex xtx
is there any type of rubber epoxy or a patch kit avail for a small tear in my studded track????.(more like an abrasion) just a small flap of rubber hanging loose, its not all the way thru the track,,,not serious....just trying to prevent it from growing further ....
thanks !!!
thanks !!!
scar
Devcon might work for your problem.Google it
DGZRT
- Feb 23, 2006
- Stevens Point Wisconsin
I work with rubber belting everyday. Most of the fill in products are a waste of money. You can fill it in and it will look good but with the flexing and pounding the track takes it will fall out in a matter of days.
The only way to fix the problem is to prepare and Vulcanize a new pc of uncured rubber in the track. best thing you can do is trim it off . If it punctured through the reinforcement cords then you need to take a round punch and punch around it. This will stop the ripping.
Many people port & stud there tracks and some places even cut the width down and most still work fine.
If it's ripped on the very edge of the track to a open window then the problem is hard to stop with out Vulcanizing .
Good luck hope it works out for you.
A picture might help for us to tell you what to do
DGZRT
DGZRT
darv
- Aug 9, 2005
- International Falls,minnesota
- 08 Apex 40th LTX
Try shoe goo , you can get it at Walmart.
Bigblue1
- Nov 29, 2007
- NY
- Sidewinder RTX-LE
Apex SE
I live in NY and there is a shop that repaired mine right on the sled.
scar
Devcon flexible 80 liquid.They use this to fix conveyor belts.Repaired a tear on my track in 2007 and still looks good and is a strong as the day I did it.It's expensive for the kit .$50 maybe
MidwestMike
- Sep 14, 2012
- Oak Lawn, IL Ride in SW Michigan
- Vector
Bigblue1 said:I live in NY and there is a shop that repaired mine right on the sled.
Can you tell us the name of the shop, and the process that they used?
People might be able to find something similar locally...
