Track porting
Charged RTX
Southern NH
Has anyone ported there track and run it on the lake for any significant amount of time. I may do my hacksaw but I am worried about losing the track. One thought I had is that if 300 hp mountain sleds use them why not 150 hp.
A couple things I've noticed is that the porting of a track on a mountain sled probably is not being studded. If you live in the northeast and have studs I doubt you could port the track also. If you are not studded then porting might be an option if you wanted to lose some weight. I choose to be studded.
Can a track be ported and studded?
Thank you. I have the same fear of blowing the track since I cut out the closed windows. I did take a hot soldering iron with a round probe and went to all four corners of each opening and burned in a radius, hopefully this works.
From what I have read on this forum in the past, what you have already done seems to be a practice other folks do. I really don't think you'll have any problems and you might get a longer slide life do to the increase in snow lubrication. Some tracks come with the windows fully opened from the factory. I was thinking of doing the same method as you but I chose to install the SLP wear pads. They both have their pros and cons and to me it comes down to personal preference.
dont port it if you stud or run anything other than deep powder...unless you want to be replacing a track very soon.
if you're concerned about weight and want more top speed...cut the lug height down...where's dirkdiggler when you need him...lol
I wasn't thinking clearly a the time, or would have gone with the SLP wear pads. Easier than cutting out the closed windows and the rubber between is still trying to run on the HY-Fax. I used the SLP's on my 800 Poo, but watch them, as they wear thin the will curl up and slice the heck out of your sliders.
iasledder: I was thinking "what type of sreen name is that" untill I thought about it for a second. :Rockon:
Thanks for the heads-up on the pads. How many miles do you think I will get out of them.
Well it started out when I lived in Iowa, but continues on as IaSledder, so's my wife. Truck plates, MN are "We Sled". See my trailer on 128" extension thread---Jim
