track ratcheting
roostersrx
indiana
I am a new 04 warrior owner i am having problems with the track ratcheting help please. also what are the must do mods thank you
Put a set of extrovert, that the best mod i ve do on mine for price, and never ratchet since.
Is your ratchet on powder ???
Tighten the track 2 turns per adjuster until it does not ratchet.(test ride between adjustments).. Track will appear extremely tight.. but dont worry... it is what must be done to eliminate ratcheting..
Must do mods as follows...
C@A PRO SKIS with 6 or 8inch carbides.
ECP filter kit and evac kit..
Simons CPR clutching
I would put the no slip Wahl Bros. drivers on for sure!! These should be put on at the factory. I had problems depending on the conditions with ratcheting and was constantly trying to find a happy meduim for Hyfax wear vs. not ratcheting. It's not worth the time to monkey with just replace the factory drivers and never worry again. With these no slip drivers I have my track adjusters set at 15mm. That is 15mm from top of nut to tip of threaded adjuster. No more ratchet and longer Hyfax wear.
