articrhinocat
- Dec 21, 2009
Track threw a stud yesterday during a high speed rip down the trail yesterday now it has a hole in the front heat ex changer,can the exchanger be pulled out without a major disassemble job .Have a friend that is an experienced aluminum welder ,but not sure if it can be done in the sled.Also thoughts of trying jb weld .Any advice appreciated ,I see other pictures of the same results but no stories of fixes .
07apexcan
Very big job to pull it out you need to weld it in the sled and replace your track if you have a pull through
yamadoo
- Jun 3, 2003
10 Vector LTX Blue 9kmiles
11 Venture GT 4k miles
86 SnoScoot(2) for grand kids
I have used JB weld after extreme clean and gave it some teeth with wire brush. This saved a trip and has lasted for years
Saved big $ and time
Yamadoo
Yamadoo
Riceburner
- Apr 14, 2003
- N.B. Canada eh
- SideWinder LTX 50th
Big job to remove.
Can be welded in place usually. Remove antifreeze first.
J B Weld works. Needs to be really cleaned well first.
Proper weld job is the best long term fix IMHO.
yamadoo
- Jun 3, 2003
Proper weld job in place is certainly the way to go if you know some one with these skills
- 8K
