stevewithOCD
Yamaha, Make me Come Back
- Jan 1, 2008
- Live CT Ride MAINE
- 900 R
2006 Apex RTX
Too bad she wont blow! lol. or good thing she wont blow actually!
This statement is why i buy a Yamaha....and why i dumped the last girlfriend
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
Here is a quick pic from last year
Wow, so those 1.6s in center area never even touched louvers? That is great to hear. There is definitely more vulnerability at rear of tunnel....as the sled/skid goes through its motion and is very active out back in comparison to the front of skid.
But its always nice to see someone run it and show he has no hits....
great to know for future, sure seems these tunnels can take a very long stud without touching.
Thanks for info and pic. This is what makes the site great, sharing info.
Dan
Doc Harley
- Oct 17, 2016
- Here & there
- '17 Sidewinder LTX SE
IDK.......guess ill be running the 1.5's this season. Might even try the super-lite pro backers. What do I have to lose?
DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
QUOTE="nightrunner06, post: 1389712, member: 20767"]Here is a quick pic from last year[/QUOTE]
Im running 192 1.575s up the middle this year, makes me feel better knowing you had no issues with 1.63s. Thanks
Doc Harley
- Oct 17, 2016
- Here & there
I think with the longer studs, track tension needs to be watched more closely. Sj kept pushing me to go longer. He was right. I was scared. Lol!
nightrunner06
- Nov 18, 2013
- madison, wi
- SideWinder LTX se
pro - x Axys switchback 800
I had very bad luck with the super lite pro backers in my nytro. Never again. I installed just like they wanted. They Would strip out when trying to suck the stud into the track and loosened up in no time.
nightrunner06
- Nov 18, 2013
- madison, wi
- SideWinder LTX se
At worst I have almost an inch of clearance all the way around in the front. Not one louver was touched. We don't run the tracks tight. But they are checked before the start of each day. 1.86" studs would be interesting.
The cat turbos have been running long studs for years.
Dan
DMCTurbo
- Nov 12, 2005
192 1.575 megabites
Doc Harley
- Oct 17, 2016
- Here & there
I remember reading tricks to install. Maybe warm water or something. I'll see what I can find.
Anyone know tricks to install super-lite backers?
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
Yes! Tap them just half way thru and forget about warm water, just use soapy water, you'll be golden.
I tried them without tapping half way and they would not tighten up properly without stripping.
I also would not use any type of air impact at all. I used just an electric drill to install into all double backer Pro-Lites to sink the head into the rubber. then finished up by hand using a ratchet to index the square shank tipped 1.45" Woody's Megabites.
I found them to take less time, and were less hassle than using std. alum backers and nuts on the indexed Megabites.
I like them soo much on my Turbo 1200 I'm putting them on my SideWinder as well. I'll only use them in double backers however for the added paddle effect. IMO the singles are rather worthless as a paddle.
geez150
How big of a pain is it to have all the square heads indexed the same way? Versus installing a traditional stud?192 1.575 megabites View attachment 133264
KnappAttack
- Feb 19, 2004
- Welch MN
Quite a big pain for sure. Its worse using std alum backers I can tell ya.
Much easier when using Pro-Lite backers and no nuts.
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
having used them before I can attest they work..however....to me it isnt worth the risk...my buddy must have hit a rock or maybe a rail crossing and we assume it cracked the plastic and ended up throwing a stud into the cooler on a 1100t...luckily figured out before smoking a motor.....with the huge rear cooler ...not worth the risk imho
DMCTurbo
- Nov 12, 2005
Piece of cake if you bought the track with the studs installed lolHow big of a pain is it to have all the square heads indexed the same way? Versus installing a traditional stud?
geez150
That's what I figured lol, well that settles that, gold diggers it is then.Quite a big pain for sure. Its worse using std alum backers I can tell ya.
