Traction question on phazer gt
Il fog
Illinois
Finally got to test drive daughters phazer
When I hammer it I break loose real bad ,,almost seems like something slips for so bit , traction is loose side ti side,
Is this common? Do I need to change adjustment on back( the strap ) ?
Steering seems ok
Are you saying that when you pin it your back end will slip side to side?
I found that my Phazer would spin the track all the time with the stock track. Especially when there is a bunch of snow on the trail. That is one of the reasons I swapped my track out for a deeper lug track.
G.B.
Gone Blue said:
That is one of the reasons I swapped my track out for a deeper lug track.G.B.
Doesn't happen anymore with the 1.5" Freeride track. The worst was when slowing down - the back end would swing widely! The new track has stopped that from happening. Its much more predictable and stable.
Spins a lot then at faster speeds moves side to side.. Almost acts as if belt slips but I don't think that is it. Yes it was fresh snow not a hard pack
Stock track is your problem. Either stud it or replace with taller lugs. The freeride 1.5 is a favorite on here, although I have run 2inch tracks (Back-country and Maverick) for 3 years now with good results.
