1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
I had contacted the manufacturer and they wanted them all back to test the hardness of them. They had my lot number from manufacturing of them.Who was the manufacturer and size and name of the stud that you bent all 144 of them that first season… what stud and manufacturer did you switch too that are working well. ???
They were not heat treated correctly.
They sent me all new studs backers and nuts to do 196 to replace my 144 bent studs.
Sno studs
Doc Harley
- Oct 17, 2016
- Here & there
- '17 Sidewinder LTX SE
I had the same thing happen to me with the Studboy plastic backers, back in my skidoo days.I had contacted the manufacturer and they wanted them all back to test the hardness of them. They had my lot number from manufacturing of them.
Manufactured in Wisconsin
I was losing backers and called studboy, they sent me new ones right away. Never one issue with the new ones. Overall I've probably got 14,000miles on their product.
Simplespeed
- Jan 8, 2022
- 1191 Sauk Lane , Saginaw, Mi. 48638
- 2006 Apex , 2017 Sidewinder LTX -LE
Information is good to know and these problems could happen to any manufacturer and when they stand behind there products thats all you can ask…
With that said you changed 144 to 196 after a quality control issue in a effort for better traction you added more studs which is normal thinking.. So you never really tested a longer stud with a better plate design at 144 and wonder if you had would your opinion have changed? Your track size is 137 ???I had contacted the manufacturer and they wanted them all back to test the hardness of them. They had my lot number from manufacturing of them.
Sno studs
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
First picture is the 144 studs.
Second pic is 196 studs. 1.86 length
3/8" above lug
I only studded due to the fact that I don't like the track breaking loose at 100mph.
3/8" above lug
Trailleader
HmmmNothing like last year. Almost dead hooked, motor bogged down. Lol.
You’re welcome
Lol
Ran 128 studs in t cats over 1/2 past lug in one inch track
More fun that 1 1/4 track on trail imo unless we received 1 foot of fresh snow
I ride groomed trails and race on the lake
It hooked on almost everything kinda like the boost bus length gapping the 998s in the videos
A little lug out of the gate on snow is good cause spinning ain’t winning
Doc Harley
- Oct 17, 2016
- Here & there
Trailleader, Last year was brutal. Horrible conditions on all the lakes (wis) if it wasn't all lumpy, it was full of slush. Couldn't make any headway.Hmmm
You’re welcome
Lol
Ecotrail & stock helix is causing bog, amongst other things. Work in progress....you know!
But had to start somewhere?!?!
Mucho gracias amigo....
Simplespeed
- Jan 8, 2022
Looking at your second picture it appears you have stressed your track a major amount at the reinforcement rods with rubber missing in alot of area’s … you might want to keep a close eye on that track….First picture is the 144 studs.
3/8" above lug
View attachment 174839View attachment 174840
Hammer70
GRIPNRIP
- Sep 6, 2015
- Niagara, Ontario.
Wow just noticed that good eye
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
That's the only section on the whole track with any lugs delaminating. It will have a real close eye on it. Looking for a new track.Looking at your second picture it appears you have stressed your track a major amount at the reinforcement rods with rubber missing in alot of area’s … you might want to keep a close eye on that track….
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
Rest of track looks mintLooking at your second picture it appears you have stressed your track a major amount at the reinforcement rods with rubber missing in alot of area’s … you might want to keep a close eye on that track….
Only missing lugs at 3 different bars.
What is your take on track?
Junk or run another season?
How many miles on it?Rest of track looks mint
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
Somewhere between 4000 and 5000 miles.How many miles on it?
3 Seasons on ot so far.
Simplespeed
- Jan 8, 2022
Not sure I would be running any prolong wide open runs , but Iam sure it will hold up for this season if you take it easy… you don’t want to find out what happens if you blow it on a tight trail at high speed…. Just not worth it…Rest of track looks mint
Tough call, I'd say you're at about 70-80% of the tracks life.Somewhere between 4000 and 5000 miles.
Doc Harley
- Oct 17, 2016
- Here & there
Nice catch, Simplespeed... I never like to tell people when and how to spend their money, with that said I'd take a peek at marketplace you can get a track for 50¢ on the dollar. Not saying you're broke, Just saying.
I might use it this year, under the condition no high speeds were being ran.
