Trailleader
- Feb 9, 2023
- Wausau Wi
- 17 9000 stage 4
Yes
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
Care to share them?
Trailleader
- Feb 9, 2023
- Wausau Wi
- 17 9000 stage 4
Look, this is a great lake racer set up, and I totally agree less is more when it comes to speed and rotating mass. This is not for the big power trail rider. This would be great if the trails were silky smooth in every condition but the reality is we have to ride over rocks, roots and wash outs and the abuse the track sees is far worse than the worst day on the lake. I only wish I could run that set up where I ride! I'm jealous!
I want to add. This said with no disrespect whatsoever. We all have different riding styles and deal with different conditions. I understand you have to ride knowing these things exist, but even still there's times when these obstacles are under the surface and you don't know they are there until it's too late.
max rolph
- Feb 10, 2021
- horse shoe valley
- 998 turbo
i usually do a 3x3 or 4x2 pattern, using double backers 4x2, but stud stars 3x3 only dwn center.... 15 scratch lines/5patterns x3 pattern on 129, on 137 i only get 12 scratch lines dwn center with 4 patterns x3 if you do outer belt you can add 4 more scratch lines on either.
REDLINE 1
- Sep 20, 2019
- ROUND LAKE IL
- 2018 TCAT
KOT Nuts
KOT Nuts are a 1-piece integral backer lake/race enhanced traction device. This 'nut' is designed to allow a trail stud or chisel to protrude 1/8" over the tip when installed. An aggressive 5.5 degree included angle and half inch tip width make this a winning setup for King of the Trail class ...
www.hellevation.com
Here you go! Best of both worlds!
Turboflash
- Mar 18, 2019
- Southern MN
Lol! Only $12 each.![]()
KOT Nuts
KOT Nuts are a 1-piece integral backer lake/race enhanced traction device. This 'nut' is designed to allow a trail stud or chisel to protrude 1/8" over the tip when installed. An aggressive 5.5 degree included angle and half inch tip width make this a winning setup for King of the Trail class ...www.hellevation.com
Doc Harley
- Oct 17, 2016
- Here & there
- '17 Sidewinder LTX SE
I've been seriously looking at similar product.Lol! Only $12 each.
Think about it, you ride to the event, break out the driver and Allen and go to town.
Event is over, remove and ride back.
If you look at one of the pics they're only adding one per bar to existing stud.
I could easily do two per bar, on a lake in 30 minutes. Just saying...
Note: other guy sells just the nut for $6. Just saying.
$600/30minutes?
I'd have to add 1000rpm of spring start pressure....let that sink in. Lol.
- 14K
