LEERIVERNYTRO
Took my sled into the dealer to have a loud primary clutch looked at and he says my trail tank is melting. Sled is an 09 XTX and I bought it used from a skidoo dealer. The tank was installed for the origional owner by a different Yamaha dealer. Anyone heard of this and is there a fix. The dealer that has it now thinks i should replace it with the origional tank and shields which I will have to buy as I dont have the ones that came with the sled.
nytro23
melting
You'll have to take the tank off. The heat shield over the header pipes needs to beaten down with a ball peen hammer on the left side where it comes in close contact with the tank, just needs a little air gap. Put a little reflective tape on it if your worried also..
Nitrousman1
Call Trailtank, they replaced my buddies for this same reason for free.
yamahahaha
just get furnace tape and put some on da tank der'
yox185
SUMMITSPIKE
Call Seth at trail tank,,,,I bought mine from him and he warrented mine with a new one ,,,,there are 3 generations of tanks new one is smaller above exhust header,,,,,,
arteeex
What's the big deal if it leaks? Won't the gas put the flames out?
LEERIVERNYTRO
Thanks for the help, I will give him a call. As for the gas putting out the fire, I am not so sure I would be sad if it didnt. LOL
sleddingfarmer
LEERIVERNYTRO said:Thanks for the help, I will give him a call. As for the gas putting out the fire, I am not so sure I would be sad if it didnt. LOL
Haha...I always wish my duramax would start on fire so I could get a cummins
stinx
Seth hooked me up with the newest version as mine was melting also. The melting was not real bad, but any melting of the gas tank is cause for concern.
07AttackGT
can you see the spot where is melting without taking the whole tank off??
LEERIVERNYTRO
yes, it was melting on the front corners where it was contacting the heat sheild. There was a reflective strip between it and the tank, but still caused some minor melting. I was able to see it just by removeing the sides.
Apex2006
- Oct 26, 2009
- McHenry, IL
- Yamaha Sidewinder SRX-LE 2019
Yamaha Sidewinder XTX 141 2017
Yamaha Viper XTX 2015
Yamaha Sno Scoot 2018
Ski-Doo Renegade XRS 850 2020
arteeex said:What's the big deal if it leaks? Won't the gas put the flames out?
Is this supposed to be funny?
yamahahaha
put some jb weld on d ol' tank der',she be like new
Ironmanstl
Had to beat my heat shield down a bit on each side as well,
No melting happened, but I could start to see the contact mark.
No problems now 700 km l8r
