yamanytroturbo
- Jan 3, 2021
- Norway
- Norway
- Yamaha Nytro Turbo
Hi. Im thinking of swapping my nytro fuel tank for an brp 850 fuel tank and seat.
I do have a 270 mcx nytro.
Will this hook up without problems? or will I have to swap out lots of hoses? And how will the fuel pump be with this swap?
Thank you
Thank you
zx4ever
- Apr 14, 2011
- Northern BC canada
- 08 nytro ty4stroke customized
I can’t comment on the 850 tank but I put a rev tank on my nytro turbo and it wasn’t that big of a deal. I had to make an aluminum cover where the fuel pump screwed in and I used 2 Arctic cat fuel pickups. One in front and one n back. And since you have the 270 kit you already have an external fuel pump and regulator. So should be a fairly easy job. Only problem I see is the back of the tank will hit your turbo, The people that do this swap use front mount turbos like impulse kits ect.
