Doc Harley
- Oct 17, 2016
- Here & there
- '17 Sidewinder LTX SE
7'x? Inline. Looking to protect flooring. Ideas w/pics would help.
Thank-you, so much.....
nadekeys
- Oct 20, 2009
- Green Bay, WI
- 2017 Sidewinder LTX LE
2009 Apex LTX GT
2008 Nytro MTX Turbo
I'm putting down ski guides as needed full length and then filling the rest of the areas with 1/4" rolled rubber flooring to protect from studs.
Sent from my SM-G928V using Tapatalk
nadekeys
- Oct 20, 2009
- Green Bay, WI
2009 Apex LTX GT
No pics yet because I don't pick up my new trailer for another week or two.
allyammies
Had a friend get me some old belting from a gravel conveyor worked great will try and get some pics
Doc Harley
- Oct 17, 2016
- Here & there
Thanks guys! I appreciate all ideas. Trailer is going to have double duty. Sleds & Motorcycles.
Very thankful and waiting to see what ideas you guys come up with.
Steve Hubbard
- Nov 11, 2016
- Chardon, Ohio
- 2007 Yamaha Phazer
2012 Arcticat F1100 Turbo
I recently purchased a 12' clam shell and used rubber truck bed liner to protect the floor from studs. I bought 2 - 4' x 8' pieces and cut them in 24" wide strips. two sheets gave me 32' of matting. The cost was around 140 bucks for both shipped to my door. A lot lighter than stall mats and way cheaper than the stuff you buy for trailers.
Doc Harley
- Oct 17, 2016
- Here & there
Pics are welcome. if it can be done.
tnc110
- Jan 5, 2015
- Sidewinder BTX SE, SRXs
Old plastic bedliner cut in straps works great for ski track.
yamadoo
- Jun 3, 2003
10 Vector LTX Blue 9kmiles
11 Venture GT 4k miles
86 SnoScoot(2) for grand kids
On my clam shell I took 1x6s set out side edges at 15 inches and worked great. They would be trippers in my 7 enclosed so still bare and holding up well after 2 seasons
Sevey
- Feb 15, 2011
- Collingwood, ON
- www.ty4stroke.com
- 2018 Sidewinder RTX
I had hard 1/4" white plastic sheets put in my Triton Tc 167. Only use guides on the ramp.
No complaints, its great cause the floor is flat, no guides to hold dirt, or trip over. Easy to sweep out.
Don't get white - every little mark shows up.
It was expensive, if I were to do it again I would consider 1/2" 'good one side' plywood.
ms
ms
ApexXTX/Viper
- May 5, 2014
- 2019 SRX, 2018 Viper LTX
Ski guides on sides and both ramps and plastic "privacy" lattice everywhere else. Typical 7' wide is 79" wide inside minus 16" (2-8" ski guides)= 63"-64" down the middle.7'x? Inline. Looking to protect flooring. Ideas w/pics would help.
96" x 4 foot sheet - 64 =32. First 4 feet of trailer "middle" is one 64" piece, next 4 feet is 32 + 32, next is 64" and so on for length of trailer maximizing use of whole sheet.
24" strips down both ramps and a few strips of whatever (rubber, wood, hyfax) on either side for traction when loading. Plastic lattice is less than half the cost of plastic sheeting (have used it as well), half the weight, same 1/4" thickness and does not trap hardly any moisture as full sheets will (even if you caulk the seams- messy and doesn't seem to hold up). Doesn't hurt to put a SS washer between lattice and floor when securing for even better evaporation and even less chance of moisture trapping. Easy to sweep out and even better with compressed air or leaf blower once you get home. Floor will last for years. White sucks (gets dirty real fast) black matches guides and doesn't show dirt near as much.
rayone02
- Dec 3, 2010
- adrian, mi
- 2012 Apex 2012 nytro xtx 2006 attak
Has anybody used spray on bedliner on flooring just wondering if it works?
Sevey
- Feb 15, 2011
- Collingwood, ON
- www.ty4stroke.com
I was at the sled show this Fall and there was a trailer there with a spray type bed liner on its floor. Looked cool but when the rep told me the price I choked.
Lets just say you could buy a lot of plywood for the cost of the spray stuff.
MS
MS
4strokeluvr111
- Aug 27, 2011
- NW Wisc.
24K miles
Apex - you have mail
Doc Harley
- Oct 17, 2016
- Here & there
No pics......What about the caliber stuff?
