nealchick
- Jan 14, 2009
- Long Island, NY
- www.briarclifflandscape.com
My manual states not to top off the tank when trailering, because it can cause a vapor lock. Anyone had this issue, I naturally want to fuel up before heading to a destination. Real concern there or what.
Thanks in advance.
Neal
Thanks in advance.
Neal
rightarm
I've never trailered with a full tank with my 03 Rx1, can cause a vapor lock and can even cause a hydraulic lock.Just my .02
airboss
In my case, I do trailer quite often with full fuel. However, like a lot of other members on this site, I installed fuel shut-off valves. This worked fine for a couple of seasons, then the valves began leaking. So I removed them and went back to the original fuel line set-up. Now, I just pinch-off the lines with general purpose (spring loaded) clamps, while trailering to avoid any potential problems as stated in the owners manual.
stewartb
Good thing I don't read much. I've been trailering sleds with full fuel for 20 years. I've never had any fuel related problems. Plus, full tanks don't have condensation problems.
SB
SB
Budweiser
I trailer my sleds everywhere and have never had a problem. I would think fuel sloshing around and getting frothy would do more harm....if any.
X2 on the condensation.
nealchick
- Jan 14, 2009
- Long Island, NY
just wondering if keeping the kill switch off would eliminate this, or is that electronic as well.
N---
N---
nealchick
- Jan 14, 2009
- Long Island, NY
bmp
lucky_7
The best thing to do is trailer it empty as far as you can, then fuel up as close to your destination as possible.
Grimm
- Apr 15, 2005
- Ottawa, Ontario
- 2018 MXZ 850
Add a set of fuel shutoffs and turn them off when trailering. Peace of mind. I know someone who encountered hydraulic lock on his RX1, very expensive fix.
nealchick
- Jan 14, 2009
- Long Island, NY
thanks guys, I'm sitting on a third or so, so I ought to be alright for a trip right.
Neal
Neal
