CANAM 4 Stroker
I bent my transfer rod. Part by part this assembly is $500. Does anyone know if you can order the complete assembly under 1 part number.
I have to believe that this assembly is a SKU item from a build sheet stand point.
TBay Sledhead
- Jan 16, 2005
- Thunder Bay, Ontario.Ca
- 06 Attak
01 SXR Long Track
Phone a dealer.
CANAM 4 Stroker
Thanks. I did in the beginning.
That is how I know that each piece ordered seperately is $500.
They are on order, as I have no time to waste , but I was just looking another way that seemed logical.
sledneck22
This seems logical: Ill sell you mine for $400 and ill just have a wheelie machine!
CANAM 4 Stroker
My experience was bad without it in the passed weekend. The trails were rough to begin with. After 15 minutes of wheelies the suspension folded down and remained locked up.
I didn't have a wheelie machine , I had a bucking bitch of a ride, with no rear pressure.
sledneck22
I know I was just being sarcastic. I was actually thinking of making a different style transfer rod that would bolt differently with some spring tension to prevent the slapping noise you hear when going over small stutter bumps at low mph. Someday when I get some time at work to draw it up in cad anyway.
CANAM 4 Stroker
I believe this could be done by dismantling and placing a spring into the transfer tube (rear most) and softening the compression of the transfer. Not a stiff spring by any means, just a dampening of the transfer.
NY AttakGT
PM TY user LANEO. He had a used one I was going to buy, but ended up getting the transfer rod covered under YES warranty. My transfer rod came apart at the body, then fell into the track and got bent up pretty good. PM LANEO....MUCH cheaper than $500!!!!!!
--Steve (O.C.)
--Steve (O.C.)
z28rx1
Just picked one up on e-bay complete w/bolts for $175 + ship from some salvage company, airwolf was the seller. Great deal i think
- Jun 28, 2004
- Clinton, Wi.
Airwolf and Laneo are both members AND advertisers here. Either will likely have what you need.
welterracer
Im really surprised no one has develeped one that you can adjust more than the OEM one..
That would be a huge seller.. I know id buy one..
BETHEVIPER
what is needed is an electricly controlled shock absorber in its place, press the button and stiffen the valving up so the transfer is stiff, hit the button again, valving is opened up so when you come to that bump you can pop it.
