cat hunter
Has any one had the jam nut on the transfer rod come loose???.Mine did on my 06 apex gt ,it backed right off and fell apart.It turned over backwards and cut a slice in the middle of the track and destroyed the transfer rod assembly.Called my dealer and had rep look at it and he said 05 had this problem but fixed for 06.Ya right!!! Because of dealer they will warranty transfer rod but not the track because of studs !!! { Not a happy camper} .Any one else have this problem!!!.
leaddog
Happend to me the first time out last year. Dealer replaced the transfer rod, but I caught the problem before it destroyed the track so I only had light damage. I installed the new rod myself and it has been fine for 2500 miles.
TurboTime
- Jan 3, 2006
- Cassopolis, MI
- 2009 Yanaha Nytro
Had the exact same thing happen to me in December on a trip in Northern MI. Removed the rod and had a wheelie machine for the next couple of days. Took it to the dealer to which Yamaha did cover the transfer rod and the track, took two weeks. I also had 96 studs in the track. Only had 300 miles on the sled..Good luck, puch back to the dealer and yamaha...May be different in Canada.?>?
cat hunter
Thanks for the reply guys. I am sure that there must be more than 3 with this problem.I would like more feedback if possible before i give yamaha a piece of my mine!!! Thanks in advance.
I've seen two break but neither wrecked the track.
RTXs
It happend to me some where around the 300 mile mark ('06 RTX). The rod was shot but the track is ok. Dealer took one off a sled on the showroom floor, instant fix under warranty.
cat hunter
Have 400 miles on since i cut the track looks like it"s going to hold together 128 on the DM today on hard pack road.Drove over very rough ice lumps and pushed 3 studs through track,was only crawling along when this happened ???
tkuss
I had this happen to me last month on my 06 rtx. Luckily I got the extended warranty and everything was covered under it so I was very happy.
kanadacat
- Aug 25, 2005
- Carleton Place, Ont
- 2017 Sidewinder LTX SE
- Carleton Place
Just had it happen this weekend.
We did a 1000 kms this weekend north of Mont Laurier and first of all the best trails I have EVER ridden. Anyways the transfer rod unthreaded and with two seperate pieces floating around for approx 200kms it gouged the center of the tracks REAL nicely. Anyways I now need a transfer rod, if anyone knows where I can get one cheap please let me know at lalondere@sympatico.ca.
cat hunter
Re: Just had it happen this weekend.
What year is your sled? My warranty is over by 3 months and they covered parts!!! 500$ for new parts .kanadacat said:We did a 1000 kms this weekend north of Mont Laurier and first of all the best trails I have EVER ridden. Anyways the transfer rod unthreaded and with two seperate pieces floating around for approx 200kms it gouged the center of the tracks REAL nicely. Anyways I now need a transfer rod, if anyone knows where I can get one cheap please let me know at lalondere@sympatico.ca.
4phsyco
Had this exact thing happen to me in January. Dealer is asking Yamaha for warranty. Hope it goes through. I think most of the problem is with the poor quality spanner wrench Yamaha expects us to tighten the adjuster with. Nothing but a knuckle scratcher and is impossible to get tight enough.
ReX
2006
cat hunter said:What year is your sled? My warranty is over by 3 months and they covered parts!!! 500$ for new parts .kanadacat said:We did a 1000 kms this weekend north of Mont Laurier and first of all the best trails I have EVER ridden. Anyways the transfer rod unthreaded and with two seperate pieces floating around for approx 200kms it gouged the center of the tracks REAL nicely. Anyways I now need a transfer rod, if anyone knows where I can get one cheap please let me know at lalondere@sympatico.ca.![]()
2006
cat hunter
The problem is mine was never touched since new .The rep said i should have taken the sled in for the 1,000 mile 250.00$ checkup and they would have checked this .YA RIGHT .Good dealer , rep NO FFEENN good!!!4phsyco said:Had this exact thing happen to me in January. Dealer is asking Yamaha for warranty. Hope it goes through. I think most of the problem is with the poor quality spanner wrench Yamaha expects us to tighten the adjuster with. Nothing but a knuckle scratcher and is impossible to get tight enough.
leaddog
You need to file the tooth on the spanner wrench sharper. It works great now.
cat hunter
I"ll give that a try !!! Last weekend son inlaw whacked his knuckles real hard and did a lot of cussingleaddog said:You need to file the tooth on the spanner wrench sharper. It works great now.
