Transfer rod spacers
michigan
To help with wt. transfer I need to replace the LOWER spacer on the transfer rods with smaller spacer (I have a 2.5 MM) , correct? any drawbacks to doing this ?
P.S. go ROUSH RACING # 97, & # 6 !! :flag:
you want to change the upper spacer with a smaller for more transfer ..if your reduce the lower it will let the skid fallout farther and also let the suspension travel more before it links....
The upper side has a 2.5 MM - O.E. There was some posts about changing the lower spacer to a 5MM or less. I know about the adjuster nuts - have the Maximum "hand job" nuts installed, but always looking for more ;)!
If you want less front end dive when decelerating you install a thinner lower washer!!
On my warrior they were 10mm.. I cut them down to 5mm..
