marc
Will a 06 Apex windsheild fit my 03 RX1 or too much work to mod..
also for good trasfer were should i set my staps tight or loose
would like to pull hard out of the hole but not wear out my sliders
played with it alot last year but never happy.
running heavy hitters,roller roster, new this year ripsaw track
rider is 215lbs.
rider is 215lbs.
Silverbullet
No the Apex windshield will not fit
If you are looking for good weight transfer I would leave the straps alone and use the controll rod to fine tune your ski lift
firecat
- Oct 22, 2005
marc
My straps are loose with 1/4 rod left and controll
rods are all the way out
Pulls ok out the hole but leves a big hole..
Should i put my straps back to stock setting if so what is the
stock setting and loosen my rear shock think my shock setting
is very tight not sure.
been reading about moving straps up or down one hole not sure what
you mean i just play with the ajustment rod on the strap.
WHAT DO YOU GUYS THINK IS BEST
