NormT
2014Vector 297 miles.. Warning light came on with the hot indicator..the code F 005..Looked at the fan ,it was not running..riding in what i thought was enough snow for cooling, temp was 26 deg. There was snow built up in front of rear heat exchanger..Is there a fuse somewhere for the fan ??What does the code F 005 mean.. Does the fan run all the time or have a sensor to turn it on as needed ?? Thanks Norm
Mileage Quest
- Apr 12, 2013
- MPLS, MinneSNOWda
- '12 Apex X-TX
We're you also low on fuel??? I thought F005 would mean you have driven 5miles or 5clicks (KM) since your low fuel indicator came on...
Here is a link to the common codes for the phazers... Should be the same for most the 4strokes: http://www.ty4stroke.com/viewtopic.php?t=67046
