Anyone know of a good replacement tool kit? I want something that will fit in the trunk nicely, and maybe have some small rachets. I like the foam idea but what happens when you need to put something in the trunk and you don't have the room?
I have a tool pouch basically made from a overnight medium sized carrying case for sundries. This is mounted to the back wall in the nose belly pan. Placed and glued a thin sheet of ply wood inside the the wall of the case to be mounted to the bulk head and used 2 pop rivets thru the plywood and case to take the punishment and then some Goop glue on the bottom side of that same wall to keep the pouch from bouncing. Use a piece of foam rubber between the tools and the top of the case to keep the tools from rattling about. Done this for years on my various make of sleds to free up the storage trunk. Not always in that same area.
