Carla 123
- Feb 27, 2017
- Lester beach
- 2015 viper xtx boosted
17 zr9000 precision stage 3
Will tuner 3s from a late model Viper fit my friends 06 apex?
yes they should fit no problem.
Port-Parts
TY Advertiser
- Sep 18, 2003
- Port Washington Wi
- www.portyamaha.com
- 2012 Nytro RTX
2018 Sidewinder BTX SE
The tuner 3s from a SR Viper or Sidewinder will not work on an older apex or any apex/vector/nytro/phazer as the ski bolt location is 9mm higher through the ski on a viper/winder tuner ski therefore when you bolt them onto an apex/vector/nytro/phazer you will find the stock ski rubber will fall out due to the difference in the bolt hole location.
good to know. means they would work well on an older pogo sled as they need that clearance.
- 12K
