Sevey
- Feb 15, 2011
- Collingwood, ON
- www.ty4stroke.com
- 2018 Sidewinder RTX
Noticed there is a metallic rattle from the heat shield area over the turbo. Only occurs at lower speeds and when the engine is under some load. It will not create it stationary on a stand.
Removed heat shield and noise went away. Re installed it and it was there again.
Anyone have a similar issue? and what did you do to fix it?
Is there more to positioning the turbo heat shield, there are quite long slots where the T30 bolts go.
MS
MS
