ak
my sled is loosing boost it started out at 16 to 17 lbs early in the day and now it only gets about 10 lbs and turns about 10,300 rpms anybody have any ideas.
Granahan378
check all of your fittings, is the air/prefilter clean? Any kinks? Do you have a boost controller or a stock mcx setup?
teerex
probably a loose rubber hose to alu tube connection somewhere inside behind the battery. happened to me and more guys.
