I want to purchase a turbo for my freshly rebuilt 03 Rx1. Anyone have any preferences?
I have a buddy with a '06 1000 Renegade and after it broke in, he had it dialed, ran right with me up to 100mph. Then I would pull away. I would like to suprise him this year and walk all over him.
Turbo $5000
Braggin rights..priceless!
Anyone know of a used turbo for sale?
Turbo $5000
Trxster
Good question, you might want to search around a bit, it has been argued about into delirium. If you're a trail rider I would put a SC on it.
SoCoRX1
i will be getting a boondocker side mount before next season. The boondocker has instant boost for those situations where you need boost right away to shoot up a hill.
For trail riding i would get the supercharger as Trx said. Instant boost as well. The turbo is more for a mountain rider that goes to very high elevations as the turbo will loose less power at elevation.
A blower is perfect. you will walk all over him in a race and be comfortable on the trail.
Skydog
Turbo!! Hands down!! Does not take any power to make power!! FREEE HP!!!
1CrazySledder
- Aug 11, 2005
- Cartersville, GA.
- None, looking now!
I have been going through this same delema. You really have to weigh out the pros and cons and decide what is right for you. There are so many decisions to make. Here's some of what I have found out during my investigating.
Stage II supercharger:
Get this one rather than the stage I. Saves you from upgrading later. To acheive decent hp on pump fuel, you will have to get the 9:1 compression pistons installed. ( $700 new ). Might not hurt to get a headspacer as well. ( Not sure on the cost, yet ) Figure on 9hp per 1 lb. of boost. The above set up will allow you 10lb of boost on pump fuel safely. This will equal to about 240hp. You can later turn the boost up to 14lbs, but It is said to use a 50/50 mix for that. ( apprx. 276hp )
You can keep your stock size fuel tank, use the stock exhaust and keep noise levels to minimum. Easier instal and takes half the time. NO MODIFING ANYTHING, except drilling one hole.
Most Turbos:
MORE HP!! I was looking at the powderlites one. But in general, figure on 10hp per 1 lb. of boost. With doing the same thing as above with the pistons and headspacer, you can safely achieve 265hp on pump fuel. This is at 12lbs of boost. You will have less fuel cap. as these front mount turbos include a smaller fuel tank. The only turbo company I have found that has a connecting pipe to use the stock duel exhaust is from Northeast Turbos. The other ones have the exhaust dump infront of the track with the exception of the rear mounts. These are louder than stock, by the way. The powderlites turbo, you will have to relocate your guage cluster to your handle bars as the intake filter has to come up through your dashboard. looks kinda kool, though.
Which ever one you get, you'll also have to invest more cash in preventitive equipment such as gauges. I'm getting the air/fuel ( $400 )
Boost ( min. $60 ), fuel press ( $60), and water temp ( $100+).
These things are very expensive to get. The money for the air induction system is only the beginning. I reccomend you do as I have been for the last month. RESEARCH, RESEARCH, and yes......MORE research. Read through the boosted section of this site as far back as you can and just read all the comments. There are alot of things to consider. Espesially if your going to go through all this just to beat one sled.
Personally, I would do this just to beat my buddy. lol
Which ever you decide, goodluck and be carefull.
They are all good it would seem. It would just simply depend on your style of riding, where you ride and the like.
Please anyone jump in and correct me if I stated something wrong.....
Vince
Most Turbos:
Vince
Bakemono
- Oct 5, 2004
- Edgerton, WI
- www.myspace.com
Turbo all the way because they are more efficent.
Skydog
14lbs supercharger i dont think you will be at 276hp? I think about 230-235 is a lot closer to real world hp.
cpr front mount turbos connect to the stock exhaust system and don,t require any other mods except for the new fuel managment system, lower compression pistons are optional depending how much boost you want to run. jeff
Trxster
What ever you get, spend the $250 on the NGK (or other) wideband 02 sensor. It amazes me how many people are jetting blindly on these sled.....when we all know if you run too lean with too much boost you go bang. Good luck.
Oh yeah, 1 last thing noone ever told me, a number of the front mount turbos do not allow access to that #4 sparkplug without removing the turbo unti
Rt
Rt
1CrazySledder
- Aug 11, 2005
- Cartersville, GA.
Skydog said:14lbs supercharger i dont think you will be at 276hp? I think about 230-235 is a lot closer to real world hp.
Sky,
Your right. I forgot to calculate in the amount of hp it takes to make more hp from the supercharger. Isn't it like 30hp or so to make about 90 boosted hp? That sounds familiar to me.
1CS
CPR Simons turbo kits still have access to the clutch side #4 plug. It not like the other 3 plugs, but I don't have to take my turbo off. Boondocker turbo kits have lots of access, they are a front mount design, Lightning Pro turbos too, under the hood somewhere.
1CrazySledder
- Aug 11, 2005
- Cartersville, GA.
Hammer,
What was I wrong on? Just curious.
Vince
Vince
1CrazySledder -- I wasn't posting in response to your post....just a general info post.
1CrazySledder
- Aug 11, 2005
- Cartersville, GA.
HAMMER said:1CrazySledder -- I wasn't posting in response to your post....just a general info post.
Vince
