ProstockBenji
- Feb 24, 2005
- Leamington, Ontario
- www.doublediamondacres.com
awesome video !
Ted Jannetty
- Nov 24, 2003
- Waterbury Ct.
- www.jannettyracing.com
cameljockey said:Ted, are you gonna turbo an injected sled?
Not for my self this time around because I am working with existing sled I have now, but have no problem doing one for anyone who wants one done.
rxrider
Jan-Ove Pedersen
- Apr 25, 2003
- Lakselv - 70N & 25E
- Norway
Great video - Now I want you to build one for me as well, too sad I'm overseas.
low blown warrior
ted. exel sled. ted for the 14 lbs boost you didn't need pistons& rods for 285 hp
Ted Jannetty
- Nov 24, 2003
- Waterbury Ct.
low blown warrior said:ted. exel sled. ted for the 14 lbs boost you didn't need pistons& rods for 285 hp
No just the right fuel.
You don't need pistons and rods untill above 350 hp.
low blown warrior
ted have you used a supercharger for ice drag racing on a sled . didn't know if one or the other would be faster for 660- 750 ' for this . i see your turbo sled ran exel what do you perfer turbo or super charger
Ted Jannetty
- Nov 24, 2003
- Waterbury Ct.
low blown warrior said:ted have you used a supercharger for ice drag racing on a sled . didn't know if one or the other would be faster for 660- 750 ' for this . i see your turbo sled ran exel what do you perfer turbo or super charger![]()
No but I raced a few, and it is no contest, the turbo is faster.
promod63
- Mar 14, 2004
- Blackfoot, Idaho
- www.thunderracingengines.com
Ted Jannetty said:low blown warrior said:ted have you used a supercharger for ice drag racing on a sled . didn't know if one or the other would be faster for 660- 750 ' for this . i see your turbo sled ran exel what do you perfer turbo or super charger![]()
Maybe it's because you haven't run across a ThunderCharger supercharged sled yet? Something that can make 20+#'s boost. Its to bad we are on the opposite sides of the country, sounds like we have alot in common. We mostly build big hp mountain sleds but I would like to build a drag sled next. Too busy to do it right now, but it's something to think about!!
ken_climb
Was looking forward to checking out a thunder charger at The Big Iron shootout but didn't see one. Hopefully next year!
Ted Jannetty
- Nov 24, 2003
- Waterbury Ct.
No but I raced a few, and it is no contest, the turbo is faster.[/quote]
[/quote]
NO! It is because of simple physics, a Turbo charger makes more hp per pound of boost Period.
I realize your trying to promote your products which are nice by the way but lets stick to reality here.
20 lb. of boost with a turbo will make more power than 22 psi boost with a supercharger.
Isn't there a little more to it than that Ted ??? Correct me if I'm wrong here but you have stated (turbo vs turbo), and I quote: "Having 20 psi of boost does NOT mean you are faster, I already proved that, I beat guys with 24 psi boost easily". Since your running 12-14 pounds that would tell me that system design and overall setup (tuner) is more of a factor than 1-2 pounds of boost on paper.but lets stick to reality here 20lbs of boost with a turbo will make more power than 22lbs boost with a supercharger
Ted Jannetty
- Nov 24, 2003
- Waterbury Ct.
HAMMER said:Isn't there a little more to it than that Ted ??? Correct me if I'm wrong here but you have stated (turbo vs turbo), and I quote: "Having 20 psi of boost does NOT mean you are faster, I already proved that, I beat guys with 24 psi boost easily". Since your running 12-14 pounds that would tell me that system design and overall setup (tuner) is more of a factor than 1-2 pounds of boost on paper.but lets stick to reality here 20lbs of boost with a turbo will make more power than 22lbs boost with a supercharger
I was taking about physics and all things being equal, turbo will make more power than a supercharger due to parasitic losses turning the blower.
promod63
- Mar 14, 2004
- Blackfoot, Idaho
Ted, sorry I did'nt want to turn this into a turbo vs supercharger thing, but LBW asked if a supercharged sled was faster or not in 660 to 750 ft race. You said it was no contest. I'm sure it would be alot closer than that if you ran up against a 14# supercharged sled. But running an 10# boosted supercharged sled (which was all that was out there at the time) against a 14# turbo is like bringing a knife to a gunfight. All other things being equal. Besides if everyone had turbos this forum would'nt be nearly as much fun.
Ted Jannetty
- Nov 24, 2003
- Waterbury Ct.
promod63 said:Ted, sorry I did'nt want to turn this into a turbo vs supercharger thing, but LBW asked if a supercharged sled was faster or not in 660 to 750 ft race. You said it was no contest. I'm sure it would be alot closer than that if you ran up against a 14# supercharged sled. But running an 10# boosted supercharged sled (which was all that was out there at the time) against a 14# turbo is like bringing a knife to a gunfight. All other things being equal. Besides if everyone had turbos this forum would'nt be nearly as much fun.![]()
NO offense taken,
All things being equal a turbo will make more power at the same boost level regardless.
And It has nothing to do with who I ran, Just Simple Physics.
Just trying to answer the questions as acurately as possible.
Wartsnuff
Ted Jannetty said:HAMMER said:Isn't there a little more to it than that Ted ??? Correct me if I'm wrong here but you have stated (turbo vs turbo), and I quote: "Having 20 psi of boost does NOT mean you are faster, I already proved that, I beat guys with 24 psi boost easily". Since your running 12-14 pounds that would tell me that system design and overall setup (tuner) is more of a factor than 1-2 pounds of boost on paper.but lets stick to reality here 20lbs of boost with a turbo will make more power than 22lbs boost with a supercharger
i almost hate to ask this... why is top fuel drag cars blown not turbo..???
if turbo made more power they would use turbo's
just my 0.02 cents
- 10K
- 6K
