neonphil
Sweet how much?? I bet you could run like 13-15 psi of boost on a bone stock Rx1 with pump gas!
What you think?
Skydog
What you think?
Skydog
peteracing
WWWWWWWater in
WWWWWWWinter
FFFFFFFFFFFFreezes!
AAAAAAAAAlcool injection..............
WWWWWWWinter
FFFFFFFFFFFFreezes!
AAHH yes you know of a Alcool injection kit?
Skydog
Skydog
looking4speed
You can just use windshield washer fluid.Try looking up Boost Cooler they have kits for cars.
SnowBandit
- Jan 31, 2004
- Maine
- www.slednewengland.com
- 2009 Nytro xtx
Lots of people run these on diesel pickups to bring down the EGT..
adirondac blue
it cools but also builds compression. Hey phil, I got the studs this week. It says to torque to 36 to 42 ft lbs. I can't get a email thru. lymans@frontiernet.net
LANEO
Guest
WATER /METH INJ
PHIL,
DO YOU PLAN ON USING THIS RAIL ON A CARB RACK ON A RX1?
I HAVE A SNOW PERFORMANCE WATER/METH INJECTION KIT ON MY CAR AND I WILL BE INSTALLING ONE ON MY RX1 IN A FEW WEEKS. I PLANNED ON SPLITTING MY SUPPLY LINE FROM THE KIT'S WATER PUMP 4 WAYS ONE TO EACH CARB, INSTALLING THE 4 SEPERATE INJECTORS JUST BEFORE OR AFTER EACH CARB (WHERE EVER I HAVE THE BEST ACCESS). THIS RAIL LOOKS INTERESTING BUT WILL IT LINE UP WITH THE PROPER LOCATION FOR EACH INJECTOR?
THANKS,
LANE
I HAVE READ ON THE NET IN A FEW SEPERATE PLACES THAT THIS WATER/METH KIT WILL GIVE ABOUT THE SAME PROTECTION AS 120 OCTANE FUEL. I HAVE BEEN RUNNING THE KIT ON MY VIPER WITH STOCK 9.6:1 PISTONS AT 10LBS OF BOOST FOR A FEW WEEKS NOW I HAVE NOT BLOWN IT UP. OFF TO THE DYNO SOON TO TUNE AND TEST EFFECT OF THE SNOW KIT.
PHIL,
THANKS,
LANE
ADRENALIN RUSH
I have an SMC kit on an 87 Buick Grand national 231 v-6 turbo motor.It has allowed the boost on pump gas to go from 16 to 22 lbs and advance timing on denatured alcohol. Have put 8 gallons of alcohol thru the motor in the last 6000 miles. It flat out works with no downsides.
Looking for a kit for my 05RX-1 with turbo. You could almost retrofit the SMC kit except for going into the 4 carbs.
sledheadgeorge
GREAT POST. I AM DEFFINETLY INTERESTED IN THIS. SLED- WATER ALCOHOL KIT WOULD BE GREAT FOR THE BIG NUMBERS.
jtssrx
Lightning Pro has been using water/alch injection for 2 years.
It works
It works
YES, what kit do we need for the RX1? I want one NOW!
Skydog P.S. Lets see, stock motor 12psi boost on pump gas!!!YES!!!!
sledheadgeorge
jtssrx said:Lightning Pro has been using water/alch injection for 2 years.
It works
DO THEY HAVE ANYTHING ON THE MNARKET YET?
jtssrx
Not all their Customers use it. Neon Phils buddy Art that has an LP uses a Snow Performance kit.
Some guys out west have made there own. I know Mr-turbo sells a Injection kit.
LP is just to busy building turbo kits to take the time to produce an injection kit.
Plus the LP kit lends itself to water injection. You simply inject it before or right after the carb and the turbo atomizes the liquid.
here is a web site for mr turbo. about half way down the page you'll see a water injection kit for 295.00
http://www.mrturbo.com/parts/106.html
FASTSLED
water injection
check out velocity racing.com all barrys kits are set up or come with water injection ,barry is a HUGE player in the turbo motorcycle world do your homework.!!!
