Turbo water temps
Topgun
Saskatchewan
Got my 2008 Nytro going and man this thing seems to run HOT. Thermostat is not stuck and no air locks with all hoses hot and rad hot with fan running. I can see that the turbo is gonna make it runner hotter but you guys with the nytros are you seeing a huge temp increase? I may have to add the mountain cooler to my sled.
Hey Topgun,
I have a digital temp gauge installed on my T-Nytro. I was riding in Revy at the end of June and the hottest it got was about 190 at idle but while running in spring snow it was around 150-160. Hope this helps.
After letting it cool and running it again I'm thinkin it's alright, BUT my gauge pod is flashing what I believe to be a temp sensor code so I guess I'll have to look into it tomorrow. But also remember you have an extra exchanger in the tunnel over my fx, not that it matters that much on the stand mind you.Thanks for the reply.
