turbo yfz 450 help
440dart
C-falls MONTANA
iam wanting to turbo my yfz450 makeing it simular to my bender rx-1 i had
what should i get for my fuel pump, and oil pump i would like to use a aerocharger but funds are low
i have a low compression piston already
also would my timeing be ok or do i need to find away to retard the timeing???
If you lowered the compression then the timing should be fine to a point.
go to www.turboaddictionparts.com for all your turbo needs.
