2005 RX1 Mountain Dan
- Dec 31, 2018
- grandjunction,co.
- 2005 Yamaha RX1 Mountain
Managed to roll it off an incline and upside down for a couple minutes before we righted it up. Motor oil running down the left vents. Started back up, runs fine. Is there a vent that would allow this upside down? Just want to be sure I didn't hurt anything. I suppose there is an egr or something that allowed this oil to escape. Help?
Brian A
well yeah the engine has a breather to let condensation out otherwise it would fill with water eventually
There is no egr that has nothing to do with the crankcase anyway
- Dec 31, 2018
- grandjunction,co.
Ok. Must have come out the breather as it should. Thanks
Brian A
yeah my only tip would be next time before you start it let it sit a good 5-10 minutes to let the oil drain back to where its supposed to be in the crankcase, you dont want it to get into a cylinder and cause a hydrolock situation
- Dec 31, 2018
- grandjunction,co.
Good point
Fortress
I did the same last week braaapn lol! I lost about a liter of oil in a minute of being tipped in a ditch on left side, had to tip it back up against the hill, was not easy!
- Dec 31, 2018
- grandjunction,co.
Ok. Must be normal. And YES! heavy machine for sure. I'm going to try to NOT do that one again.
- Dec 31, 2018
- grandjunction,co.
Took about a liter of oil as yours did. I'm a bit worried, if you couldn't upright it quickly, you may lose enough oil, it can't be started, Lousy design for sure
