Went for a ride yesterday. When I got home, I allways jump a little rise back onto my front lawn. When I went to jump, as i have done 1000's of times before, I hit a small rock with the right ski (I sort of slid into it side ways.) The hit broke the right lower, rear a-arm bolt and bent the very end of the arm at an 30degree angle.
I removed the a-arm and heated the bent end with a torch, cherry red and inserted a rod into the bushing hole and bent it back into place. When I put it all back together the right shock is 1/4-3/8" further back between the top a-arm than the left side. Either the a-arm is still slightly tweaked or the front clip is tweaked. O-well live and learn, it still rides ok.
