snowdust
- Oct 26, 2003
- Northern Illinois
- Sidewinder
Looking for feedback on what setups you have found to work well with the heelclicker two-speed weights. It looks like the black spring might be the way to go with a bolt in all three holes, but want to see if anyone has experience running this setup. This is for an 06 Apex GT. Thanks!!
CANAM 4 Stroker
- Oct 26, 2005
- www.klim.com
- 2009 Yamaha Apex GT
This set up is best found by searching for "drag&fly" or a version of those words. You will find Turk recommending to me a set up that works well and some discussion around it.
snowdust
- Oct 26, 2003
- Northern Illinois
- Sidewinder
I am actually looking for a setup with the two-speeds and not the drag-n-flies, but thanks anyway!!
yamadog1
2 speeds
turk we really miss you, i hope your in snow up to your azz, i for one can say i miss him.
now try 1 bolt in heel with 1 washer and bolt in inner the rest use stock
springs and secondary 3-3
CANAM 4 Stroker
- Oct 26, 2005
- www.klim.com
I agree. I just noted what I think he did for this site in my profile
yamadog1
2 speeds
IH8CROWS
- Jan 19, 2009
- Wisconsin
- 11 Apex
16 Apex
What I use..
To: IH8CROWS
Posted: Wed Feb 02, 2011 9:42 pm
Subject: Re: Heel Clicker 2- speed Quote message
use stock primary spring & 1 bolt in the heel & see how that works.
To: IH8CROWS
Posted: Wed Feb 02, 2011 10:16 pm
if that set up does not work go with 1 bolt 1 washer in heel / black hc spring & rest of weight empty.
To: IH8CROWS
To: IH8CROWS
snowdust
- Oct 26, 2003
- Northern Illinois
- Sidewinder
Keep em coming! Has anyone actually ran these and dialed theirs in or were these setups to try? Yes we all will miss Turk. If this question isn't up his alley I don't know what is. I am trying these weights because he liked them so much. Thanks guys!
IH8CROWS
- Jan 19, 2009
- Wisconsin
- 11 Apex
16 Apex
I'm using his first suggestion at the moment.
My sled is not broken in yet so I will see then for sure.
But the way it sits now the first setup works very well.
He told me he tried all kinds of setups and these were the two he told me to try.
2011 xtx
2011 xtx
snowdust
- Oct 26, 2003
- Northern Illinois
- Sidewinder
What year is your apex?IH8CROWS said:I'm using his first suggestion at the moment.
He told me he tried all kinds of setups and these were the two he had come down to.
Mad Russian
The white spring worked the best with all the testing we have done! The set up that heelcliker gives u works the best from evrything that we tried. Start with that and add waight as u need it. The black spring was much slower for us.
snowdust
- Oct 26, 2003
- Northern Illinois
- Sidewinder
I am buying a used set so I may not have their recommended setup. Do you know what it is for an 06 apex?Mad Russian said:The white spring worked the best with all the testing we have done! The set up that heelcliker gives u works the best from evrything that we tried. Start with that and add waight as u need it. The black spring was much slower for us.![]()
Mad Russian
shoulder = just a black allen bolt, center = same, tip =no bolts and the white spring. If your sled is stock then this should work great. Give it a try.
yamahahaapex
im running one bolt, 2 washers in heel. everything else is empty. using the black hc spring. once the 11 broke in this set up was not good for me anymore as my holeshots were terrible with the extra power it would seem. I was told to run a y-s-y this year. see how that does.
i also talked to randy at supertorquer and although it does say not to add more than 2 washers to any area you can add a 3rd for sure, maybe a 4th but will need a longer screw. Im thinking of leaving the black spring in and chcking the clearance with the 3rd washer on to help tame the holeshot.
snowdust
- Oct 26, 2003
- Northern Illinois
- Sidewinder
Mad Russian said:shoulder = just a black allen bolt, center = same, tip =no bolts and the white spring. If your sled is stock then this should work great. Give it a try.![]()
I'm not a big fan of that white spring for trail riding. I used it for a while with the drag-n-flies and found the engagement too high for my liking. If it was faster for you, I am tempted to go back to it though. What setup with the black spring did you try that was slower?
