SIKEWARD
I just got my new header from ulmer today. The old header has a mesh wrap around the male end that plugs into the muffler (female end) I would describe this mesh as a gasket material for sealing the header / muffler connection. Ulmer's instructions don't say anything about reusing this on the new header. Plus i'm not very sure it is reusable. What have you guys done on yours? Thanks
Phyxius74
Reused it. It's a bit of a PITA to get out but it should definitly be possible without damaging it.
thetruck454
I'm also gonna use a tube of RTV exhaust sealer on that joint and cover the donuts on the flex pipes.
SIKEWARD
Thanks for the replies. I'll just order a new one. They are only $15. But my ? was answered do I need it? And the answer is Yes!
They usually stick to the muffler ~ actualy have to beat them out. Wish i knew they were only 15 bucks i would have saved myself an hour of messing around.
Crewchief47
- Jan 16, 2006
- McGregor, ON Canada
- 2008 Nytro MTX 45th
Ya, mine stayed in the muffler when I did mine last year.
mike3577
- Oct 18, 2009
- auburn hills,mi
- 09 nytro xtx, 8 inch slydog powederhounds, mbrp silencer, ulmer racing clutching, fast track studs,cr10ek sparkplugs,
ya just reuse it pry it out and gasket seal it if you want but not nesasary.should still be good if your sled has lower miles.i reused mine works fine
