jeff_yam
- Oct 6, 2010
- Quebec
- 2016 Viper LTX-LE
Actually if you take your front end apart and start measuring you will find that none of the bushings are an off the shelf size that is a direct replacement. The other thing that sets our bushing kit apart from the stock or other aftermarket bushing kits is the fact that we hold our tolerances to 0.0005" and also that it is a very strong super oilite material.
You are right I have checked and only 2 of them has standard dimensions in Bronze SAE 863 super oilite material. But they are really cheap, about 2$ each.
