pedros83
- Nov 19, 2015
- Blackstock, ON
- 2010 Nytro XTX
Anyone out there know where i can get an aftermarket bushing kit for the front spindle bushings? I know ulmer has them but trying to find something in canada
sxvipers
Up Bushman on forum has stainless steel set. Very nice. Search them, no one is disappointed with them.
Sent from my Nexus 5X using Tapatalk
Yamatario
- Jan 8, 2009
- SW Ontario
- 2018 LTX SideWinder
2015 Viper LTX DX
2009 Nytro XTX
I just got mine from Brian's Yamaha, about $4 each. You can also compare at Mcmastercarr
pedros83
- Nov 19, 2015
- Blackstock, ON
- 2010 Nytro XTX
Are they the plastic factory replacements?
Yamatario
- Jan 8, 2009
- SW Ontario
2015 Viper LTX DX
2009 Nytro XTX
Yes factory black plastic. They also have the brass but can't remember how much more. Since this is my backup sled and 29000 km on first set, figured stock ones did fine.
Dr. FeeLGooD
Yamaha spindle bushings are tin like. The A arm bushings are plastic. I have UP Bushmans stainless steel spindle kit with about 4000 miles and are still tight as when I put them in. Cost is considerably higher than $4.00 but I am not complaining.
Yamatario
- Jan 8, 2009
- SW Ontario
2015 Viper LTX DX
2009 Nytro XTX
Sorry, I was referring to A Arm bushings.
porkchop
With the Dr., UP Bushman....
herndonp
Absolutely UP bushman no more slop in the skis!!
Pete
Pete
grizztracks
Tech Advisor
- Feb 24, 2005
- Scio, NY
I'm not sure if he's still making them. Last time I heard from him was a few years ago.
pedros83
- Nov 19, 2015
- Blackstock, ON
- 2010 Nytro XTX
Can someone breakdown the bushing parts in the spindle. So theres a metal bushing built into the spindle... and metal sleeve inside that which the bolt passes through with spacers on either side? Something im missing? Arent there suppose to plastic bushings somewhere?
grizztracks
Tech Advisor
- Feb 24, 2005
- Scio, NY
The stock setup has two bimetal bushings in the spindle which tend to wear quickly. There is a sleeve that slides through the spindle's bimetal bushings then a spacer is slide over the sleeve to set the ski offset.
This is the UP bushman install: http://ty4stroke.com/threads/spindle-bushing-removal-premium-bushing-upgrade.110774/#post-983279
Stock bushings:
Stock bushings:
pedros83
- Nov 19, 2015
- Blackstock, ON
- 2010 Nytro XTX
Thanks grizz. That was most helpfull. Looks like the previous owner did away with the bi metal bushings and fabbed something similar to up bushman. What is normal play tolerance? 0? Lol
SteelerJim
I got a set from Bushman last spring
grizztracks
Tech Advisor
- Feb 24, 2005
- Scio, NY
I just checked his profile and he was on TY yesterday but hasn't posted in awhile so maybe he still makes them.
- 46K
