just tell them it is an apex xtx as it is the same suspension.
Mtn-bike
- Mar 1, 2020
- New Hampshire
- 2010 RS Vector LTX
Should I order from Elka? The AT website looks like it ISN'T set up for ordering.....
ELKA looks to be $825USD.....same as HYGEAR?
RobX-1
- Coldwater, OH
Why does the Elka Stage 2 IFP Rear Shock for the Apex XTX Singleshot suspension not show this offset reservoir? Was one of the reasons I was considering the Hygear option. If it's an add-on option, do you know how much more it added to the cost of the Elka shock?This shock has an offset reservoir on it so it won't contact the grease fitting. Relay rod is spaced out 30mm on the left side and 10 mm on the right side.
Mtn-bike
- Mar 1, 2020
- New Hampshire
ELKA stage 4 or 5 is $825....shows the reservoir. It doesn't list the stage 2.
www.elkasuspension.com
APEX X-TX (144), 2014 to 2015 Archives
RobX-1
- Coldwater, OH
Although I've always had reservations concerning the Singleshot suspension using an air shock vs a coil shock, I have close to 10,000 miles on the Fox Float that came with my 18 XTX and it has yet to give me a reason to replace it other than having a spare/backup like @maim has with his Apex's. With that said, I also ensure my Fox Float was and is periodically serviced by @cannondale27 to at least give the a shock a fair shake.Would you trust the air shock to a 2500 mile week in very remote parts of Canada?
Mtn-bike
- Mar 1, 2020
- New Hampshire
Understood......I have a friend that lost one on an Apex. It's a huge problem and will ruin a trip for more than just me if it fails.
AND...the XTX that I just bought has 8k miles on it.
RobX-1
- Coldwater, OH
Ah, I see the difference now, you're referring to the 144" XTX and I was referring to the 146" XTX. With that said, the 144" wasn't actually consider the Singleshot suspension, correct? That came out in 2016 which is when the Apex went from a 144" to a 146".ELKA stage 4 or 5 is $825....shows the reservoir. It doesn't list the stage 2.
Mtn-bike
- Mar 1, 2020
- New Hampshire
My bad.....I should have referenced the 146.
ELKA doesn't list anything newer than 2015 that I can see.
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
Those years dont have the newer singleshot suspension in it. Need to look at 16 and newer.ELKA stage 4 or 5 is $825....shows the reservoir. It doesn't list the stage 2.
RobX-1
- Coldwater, OH
But link you posted was for the 144" XTX and not the 146" Singleshot.
Like @1nc 2000 stated, you need to click the link I posted to Elka's website as that is for the Singleshot which your 2017 Vector would have. Even though their web page only list the year 2016, the Singleshot did not change from 2016-2018.
Mtn-bike
- Mar 1, 2020
- New Hampshire
Rob.... I messed up, thought they were the same. My other sled is a 2011 Apex short track.....anything that starts with 14X looks like a Cadillac to me!
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
I had purchased mine in 17. I had a fitment issue with it. The reservoir was directly below the shock and the compression know would hit the grease fitting on the cross shaft. We resolved that issue with the offset reservoir. Dont know why they don't offer this setup. Maybe worth a call to Acceleratedtechnologies.ca if your interested.Why does the Elka Stage 2 IFP Rear Shock for the Apex XTX Singleshot suspension not show this offset reservoir? Was one of the reasons I was considering the Hygear option. If it's an add-on option, do you know how much more it added to the cost of the Elka shock?
Mtn-bike
- Mar 1, 2020
- New Hampshire
That's what I was thinking.......but the price for the '14-15 is almost the same as the HYGEAR......I was hoping for something closer to $500 if there is such a thing. I think that's what a spare Fox Float would cost.
Looks like our first storm coming on Friday night.....6-12" predicted.
