Valve adjustment on a 2006 Apex/Attak
THKSNOW
Smooth Operator
Millecoquin Lake, Engadine, MI
2013 RS Venture GT
Anyone had this done on their sled? How much has to be taken apart and what might be the cost to have a dealer do it. Thanks!
I think you mean valve adjustment. I will fix title for you. (once I figure out how)
I'm doing some searching looking for a step by step for this. I'd like to adjust my valves this spring.
It's in the manual if I'm not mistaken.
Yup Chapter 2 pg 9.
Well I got it figured out. The cables are not the issue. There's a check valve in the gas tank that is not working properly I suspect. New one should be here this week. Every other thing I checked was within spec. I did the co adjustment down to negative 15 this helped but it is not the cure. I will post up with my results. I was leaning towards valves or a pinched vacuum hose.
